is it ok to reuse head bolts?
Old 03-08-2009, 03:23 PM
2000NavyZ's Avatar
Default is it ok to reuse head bolts?
is it ok to reuse head bolts??
Old 03-08-2009, 03:30 PM
tuffguy's Avatar
no, either new ones or ARP
Old 03-08-2009, 03:36 PM
deuce_454's Avatar
what he said, they are torque to yield... so once you torque them down they stretch beyond yield limit and should be discarded after first use
Old 03-08-2009, 04:07 PM
theblur98ss's Avatar
do not reuese them. If you plan to be in there very much put studs in and be done with it.
Old 03-08-2009, 04:15 PM
1Bad00SS's Avatar
I say go for it.. use the gaskets, too.
jk, yea definately not, however I know someone who actually did reuse the stock bolts and his engine went a long time on a 175 shot before popping a headgasket.
Old 03-08-2009, 05:21 PM
Shawn MacAnanny's Avatar
No you cannot reuse them
To use stock head bolts you need both a torque wrench and a torque angle gauge. I have this one and it worked extremely well when i swapped the head gaskets on my Duramax, 36 bolts that had to be torque down 4 times to about 150lb.
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Old 03-08-2009, 07:17 PM
Moderator
davered00ss's Avatar
No, the stockers are torque to yeild and a one time use. Replace them.
Quick Reply: is it ok to reuse head bolts?
