Demand-lighting circuit
Old 03-09-2009, 02:29 AM
Qcon's Avatar
Default Demand-lighting circuit
Hi guys, I want to wire in LEDs under the hood, but I want to tie it in via a toggle switch to the demand lighting circuit. Basically I want it to have power when the key is turned but will turn off with the interior lights after the delay if I accidently leave it on. Where would the place to tap into that either in the interior or under the hood? I hope that makes sense. Thanks in advance.
Q
Old 03-09-2009, 08:33 AM
Nova5's Avatar
Why would you want to light the engine bay with the hood closed?
anyway. should be able to do that from the drivers side fuse box. Just have to locate a fuse that is handled by the RAP system. Tie it in there, likely have to find that wire on the back side as there isn't alot of work room on the front. run that new wire out through the firewall and use a relay to control the LEDs in the hood with a direct battery tap.
RAP isn't part of the lighting, but would certianly shut off when you open the door as its the Radio/Window power circuit.
To tap into the lighting would be easier. Pull the Headlight control module out and find the wire that receives power when you turn the brightness wheel all the way up. tap into that wire for your LEDs. No real need for a fuse since the lighting circuit's fuse will be protecting the new stuff as well.
Old 03-09-2009, 10:43 AM
Ungrounded Moderator
WhiteBird00's Avatar
I agree with Nova5... wouldn't it be easier to install a mercury switch so that the underhood light only goes on when the hood is open?
On the other hand, don't use the dimmer wire from the dash switch because it works on a voltage reduction that doesn't work well with LEDs. You also don't want to use the courtesy light power because although it will go off when the BCM "goes to sleep", it will be on all the rest of the time (like the map lights are available all the time - same power circuit).
Old 03-09-2009, 10:49 AM
Nova5's Avatar
Thats why i told him to find the one that gets power when you go to the full on (Cabin Lights On) position. That one gets all or nothing.
Old 03-09-2009, 10:54 AM
You're right of course but I wanted to make sure he didn't use the dimmer circuit. Most people don't realize there's a separate circuit when the dimmer is turned all the way 'til it clicks.
Old 03-09-2009, 10:58 AM
Nova5's Avatar
True.
Old 03-09-2009, 02:03 PM
Qcon's Avatar
Cool, thanks for the help, guys!
Q
Old 03-09-2009, 02:49 PM
Copy & Paste Moderator
VIP1's Avatar
A mercury switch could accidentally be triggered by normal car movement. It may be a better idea to use a plunger switch.
Old 03-09-2009, 04:07 PM
Nova5's Avatar
flickering an LED isn't harmful to it, so a merc switch would work well enough.
Mount the merc switch so when the hood is opened on a slight downhill incline is at about 25-30 degrees. When closed the angle will be so severe that the chance of a bump tripping it will be negligible.
Quick Reply: Demand-lighting circuit
