Couple Of Problems From Last Year......
Well I have put it off for long enough and its starting to get nice out and about time to get the car back out, but I have a couple problems
First off after the car is warmed up it has problems restarting. I changed the coolant temp sensor, but that didn't change anything. It acts like its flooded and I have to hold the gas pedal on the floor to get it to fire back up. I almost think that the injectors are leaking down, but it will do it right away of within an hour. So if I stop and fill it up with gas its hard to restart. I'll do a test and see if its loosing pressure and then if it is try to find where its leaking.
Second problem and it has only happened a handful of times is that the car seems to loose idle ocasionally. It seems like it does it under firm braking most of the time, but sometimes just an easy first gear takeoff then push the clutch back in again it will idle down to 300 rpms or so then slowly come back up to about 900 rpms
Kind of hard to explain the 2nd senerio, but if you need more info let me know.
Thanks in advance guys
Huh, thats the first that I have thought about that. I have the ICM spaced out from the head, but I'll get a new coil since mine is still stock and see if that helps.
Is there anyway to test the ICM or just have to buy a new one?
Thanks
Thanks
I would look at either the o2's or the MAF for you issue of problems after the car warms up.
I would hook up a vacuum gauge to the manifold and verify that you don't have a vacuum leak (leaking intake manifold seal/gasket or a torn intake elbow, etc). That could be the cause of your idle problems. Also a faulty IAC can cause the same problem.
Yes you can test the ICM, but it's difficult to find an Autozone that carries the right connection.
Could get a new IAC from GM dealer????
