CDT crossovers
CDT crossovers
I just picked up some CDT CL-61CV's from Kee. Are you guys installing the CDT crossovers when using the stock Monsoon amp and HU? Will it still sound acceptable using the stock crossovers? ....Car is '98 Trans Am btw
Ungrounded Moderator
As vjo90rs8 said, you have separate wiring for the mids and tweeters (both Camaro and Firebird). Crossovers are designed to take a single channel (pair of wires) and split the signal between two speaker components. Your factory wiring already has high-pass filters for the tweeters and they do a fairly good job. I have CDT components in my doors and I am pleased with the way they work with the factory wiring.
