285/35/18 on all 4 corners mounted on 18 x 9.5 45mm offset
Old 03-11-2009, 12:05 PM
RSTEWART's Avatar
Default 285/35/18 on all 4 corners mounted on 18 x 9.5 45mm offset
does anyone with a 4th generation Fbody have this combo on your ride with NO Fitment Issures??,
ON ALL 4 CORNERS - 285/35/18 on 18 x 9.5 " 45 mm offset wheels.
I am considering the wheel tire combo for my T/A
Wheels are the TSW Indy 500 chrome,
Need some imput here ASAP !!
Old 03-11-2009, 12:22 PM
02NBMWS6's Avatar
That will be just fine.
Old 03-11-2009, 01:45 PM
Jscotty's Avatar
They'll work. Last time I checked a 275 width is a little cheaper than a 285 width. I think it fits a little better too. Just something to keep in mind; everyone likes saving money.
Old 03-11-2009, 03:43 PM
99Bluz28's Avatar
Post some pictures when you get them!
Old 03-11-2009, 05:03 PM
RSTEWART's Avatar
WILL not be till May as i live in the Michigan area & the T/A will not be out of heated storage till first week of May.
Will post pics once i purchase.
Old 03-11-2009, 05:09 PM
fccs's Avatar
The front may rub a little bit on turns though but other then that it should be a easy fit
Old 03-15-2009, 08:12 PM
topdj-com's Avatar
TSW Snetterton 18 x 9.5 and 275 35 18 on all 4 that will be ok right?
Old 03-15-2009, 08:19 PM
fccs's Avatar
275s would be fine, sometimes people have small issues with rubbing on tires wider then 275 up front though. I know a few people who have run 285s up front fine, but other have had rubbing a little bit. 275s up front are always fine tho
Quick Reply: 285/35/18 on all 4 corners mounted on 18 x 9.5 45mm offset
