317's and cam stock ls1
My plans are to go turbo in about 6 months. I want to go ahead and put something like a 224/224 cam in and while i am there i figured might as well put the 317 heads on and change the lifters and trays and so on. How will my car perform after those mods until i get the turbo kit on? I have pacesetter lts, 3600 converter, and ls6 intake. Will the 3600 converter keep me out of the low end loss from the lower compression?
ive been trying to get somewhat of a straight answer on this but havnt got it yet.
but heres an interesting thing i found on the CR calculator.
317 heads on 5.7L with .040 cometics gaskets has the CR at 9.9:1 to nearly 10:1 CR depending on gasket bore diameter. I used 4.010 to get it to 9.9:1 CR.
Id image that with 317 heads, .040 cometic gaskets, and a 224R cam would be damn near stock feeling at low rpm. The plus side is that the top end will flow a hell of alot better and you pick up power still without noticing any difference in N/A. you might lose maybe 5hp to at the worst 15hp with out boost hooked up, but once you boost it, it should really pick up. I also keep reading that .040 gaskets place a better quench and there for less heat stress or somthing like that, someone needs to better explain it since i cant word it right lol
anyone try this by chance?
