ignition relays do thet go bad ?
Having starting problems,starts when it feels like it. I have all power in the dash lights,battery is good . It does not turn over sometimes. Just one click. Try it later and it starts right up fast. I took the ignition relay out and tapped on it and it started. Took it for a drive,got home turned it off and tryed to restart and nothing so I tapped on the relay and it fired up again. Does the relay send power to the starter or solonoid ? . The car has 28,000 miles.
I thought my starter relay was bad, ended up being corroded starter terminals. I ended up bringing the new starter back, as I removed the old one, cleaned up the terminals, and putt it back on. Never a problem since. Hint: Don't take the starter apart, you need about 17 fingers to hold everything in place to put it back together.
