procharged 346
procharged 346
what are your recommendations on the valves on a stock set of 317 heads
do i need to change them,or will i be fine just changing seals and springs
also what about my cam 248/254/116lsa little over 600 lift
what do you guys recommend i will be throwing some 317 heads on my forged 346 ls1 and ultimately shooting for about 16psi on a d1sc
will the stock valves be fine
and is that cam too much duration or will it be allright on a supercharger
Valves will be fine. Cam is big but should work well with the 116lsa. Don't know if the 317s alone will lower cr enough for 16psi on pump at least without a methanol kit. Go for it. You'll be fine. I'm guessing you're referring to a D1sc.
what do you guys think,from what ive seen it looks like ill be ok
also i have a 4000 n2o stall,is the converter going to be good
i know my setup wont be optimal but i want to know will it work and be a decent setup,doesnt have to be perfect if it saves me some money and is still plenty driveable/tunable
sounds good guys i was thinking with the supercharger i would be okay with my cam
any other tips to help me out?kinda new to the boost game, ive been a bottlebaby as some of you guys might say lol
