Retorque heads
Old 03-16-2009, 08:23 AM
maxgee's Avatar
Default Retorque heads
I have about 11k miles on my turbo set up with the 6.0 ported truck heads using ARP head bolts. Curious if you guys retorque your heads at certain intervals?
Old 03-16-2009, 10:12 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I rechecked/retorqued my heads after the first couple heat cycles when the heads where installed. After the first couple of heat cycles when the heads are installed, there is no need to retorque them again.
Old 03-31-2009, 07:13 AM
cjg454ss's Avatar
what did you torque them to? lbs?
Old 03-31-2009, 10:02 AM
ls1290's Avatar
The amount recommended by ARP with assembly lube. I believe 75 ft lbs.
Quick Reply: Retorque heads
