Heads for Turbo car-- is ported worth it??
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Is anyone making 700whp with stock 317 heads? That is my Hp goal and I'm at a toss up on whether I should get a set of ported Patriot or PRC 317s or just use the stock ones I have and upgrade the springs. In other words could the stock heads achieve those power levels? Would the stock valves be OK?
Thanks,
Frank
Thanks,
Frank
Thanks,
Frank
Thanks,
Frank
Id like to hear some of this too. I just got my truck running and my 317 heads are basically stock. They have larger stainless intake valves and upgraded springs/retainers but are otherwise pretty much stock. I have a T76 q trim ball bearing turbo pushing through them.
On my old procharged FRC i did it with the following:
346, Stock crank, callies rods Diamond pistons, stock 99 vette heads w/ spring upgrade ~ 9.4:1, 226/230 595/595 114 comp cam, LS6 intake and stock TB, 1-3/4 headers & D1SC
@ 11PSI = ~640RWHP
@12psi = 670
@13.5 = 706
No meth on 93
@ 11PSI = ~640RWHP
@12psi = 670
@13.5 = 706
No meth on 93
825 RWH at 5400 @19 psi S374 Bulls Eye Turbo
Stock Six Speed
Stock Rear
Stock 98K LQ9 317's with dual PRC Springs and LS6 cam.
also made 749RWH with the stock 34K LS2
I just broke the main shaft in the trans after 1 1/2 years and about 4k street miles of abuse at around 950 flywheel hp
Stock Six Speed
Stock Rear
Stay away from the patriots. You'll have much better luck with ported 317's by someone who is reputable. Reputable is key especially on a boosted car.
Dont have someone take the swirl bowls out and get someone with good experience.
-Wade
-Wade
