Fueling & Injection - I Need Help With My FPR!
InsaneDomestics
03-16-2009, 09:14 PM
I have an Aeromotive FPR and my Fuel Pressure Gauge goes 0-60, when I start my car it bounces around 60 and pegs out. I try to adjust my pressure by turning the set screw both ways and my pressure doesnt go up or down. Any Ideas why I can't adjust?
C5Fire
03-17-2009, 08:12 AM
Did you disable your factory regulator first? If not, you now have two regulators fighting to gain control of your system.
InsaneDomestics
03-17-2009, 09:48 AM
I have an external pump and everything. I unhooked my factory fuel pump so the stock FPR shouldnt be in use should it?
InsaneDomestics
03-17-2009, 09:53 AM
Well wait a minute, isnt there a FPR in the return line???
Rapin'Ya
03-17-2009, 09:58 AM
You've got one in the tank of the 98's that you should have removed completely if you were going external. And assuming you have gotten rid of the stock fuel rails as well. The other possibility is that your regulator diaphragm is busted. Are you connecting a vacuum source when setting it or no? If there is a vacuum source on it when you disconnect the line does fuel spray out?
C5Fire
03-17-2009, 11:07 AM
If you still have the fuel pump basket in there then the regulator is still in the system. Are you coming out the bottom of the AFPR and returning back to the factory "T" that goes back to the tank? If so that is your problem. Disconnect the return line and put it in a 5 gallon gas can. Key the pump on and you should be able to adjust pressure now(Be careful not to blow yourself up). Just take the regulator out of the basket and you should be good to go.
InsaneDomestics
03-17-2009, 12:29 PM
I got it, I forgot to take out the Factory FPR that is in the return line. Shes runnning good now, Thanks for all the help....
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
