I screwed up
I screwed up
okay i messed up big time. i put new gauges in my car today and had a brain fart and forgot to check where the needles were before. so everythings back together and i know i didnt get them back where they were. any ideas? or am i screwed? any help would be greatly appreciated.
after you run your car a while stick your temp needle back on to right below 210. oil-guess your normal oil pressure? rpm-your average idling rpms, mph should sit right on the bezel, battery-guess your normal voltage and then gas-either wait till you fill up or run out, your choice sorry not to much of help but thats what i would do at the moment in your situation. not sure about this but MAYBE if you get a handheld programmer it should be able to tell you the rpm, oil, volt, and temp.
