80# injectors enough?
You should be okay, weve been factoring 25% larger injector for E85 vs gasoline, and its worked quite well.
A injector thats 80lb @ 3 bar will flow 92lbs @ 4 bar, you should be okay with that.
well ive decided to go nitrous instead of turbo after a long hard thought session/numerous layouts of setups and plus i have a buddy who can get me fills cheap so i think ill go 42#ers on my 5.3 with e85 and spray(hoping to go 200shot with ARP rod bolts and head studs)
If that question was for me this is what Nate said.
"E85 requires about 33% more fuel volume than standard gas. So if your goal is to get to 550rwhp you are going to need at least 750rwhp worth of fuel. 60# inj. should make that kinda power with good fuel pressure. I would rec. our Stage3 Street kit with the Dual Lonnies/Racetronix fuel pump setup. It has the best reliability and will handle the fuel delivery you need…very safe. I would forgo the meth as it is just a patch for not enough fuel. If you wanted more power you could just turn up the boost the fuel system can handle it."
