Schwanke Engines Tax Time Specials
Well, here are the deals for the month:
6.0L 408/415 Cast Iron Gen 3/4 Stroker Short Block
SAVE $200
415 cu.in. 6.0L iron block
4.065" Mahle Forged Pistons
Powepack Ring Set
4" Stroke Forged Steel Eagle 24 or 58x Reluctor
6.125" Forged H-Beam Engine Tech Rods
ACL Performance Coated Rod and Main Bearings
Digitally Balanced
Square Bored and Decked with Rottler F-65
Fully assembled
Now $2999.99 + shipping
Extra's found on website!!!!!
This is a drop in shortblock ready to run with 0.650" lift and all but the LS7 head. We have run these in racing as well as on the street.
Also, if you purchase this or any other shortblock, you can get the Complete LS3 Head kit which includes intake rockers and stands for $999.99
https://ls1tech.com/forums/sponsor-s...9-99-more.html
Complete Set of reconditioned 317 Heads: $399.99 with exchange
Casting number 317 6.0L LQ4 Truck Head
Decked to 70 cc chamber
Valve Job'd
New LS2 Intake and Exhaust Valves
New Seals
New LS6 Valve springs Good to 0.570 " Lift
To upgrade any of our cylinder heads to the 165-A's, add $195, or to the 195-A's add $240
SAVE $200
Powepack Ring Set
Digitally Balanced
Fully assembled
Valve Job'd
New Seals
block
SAVE $200
Powepack Ring Set
Digitally Balanced
Fully assembled
Valve Job'd
New Seals
SAVE $200
Powepack Ring Set
Digitally Balanced
Fully assembled
Valve Job'd
New Seals
Last edited by Warped; 03-30-2009 at 11:39 PM. Reason: posted name an phone number
Interseted in this block, spoke to Tim yesterday and it sounds like this is what I can use.There was an issue with the cam sensor position because I have a 2006 ls2 that is blown and will be using all removable parts to put on this block, he also suggested the steel rings because of the small blower I am putting on it,will call to tomorrow at some point to comfirm order and arrange payment. Brian Holmes
Sounds good Brian.
