AIR question
Old 03-18-2009, 12:29 PM
Black02SLPSS's Avatar
Default AIR question
Hey all, i went ahead and deleted my AIR system finally, and now my dash vents dont work. Is there some vacuum line i missed getting capped off and if i did where would it be? Thanks
Old 03-18-2009, 12:47 PM
red02Hawk's Avatar
weird, so your hvac system doesn't work at all, or air just doesn't come outta the dash vents?
Old 03-18-2009, 01:47 PM
Deviant LS1's Avatar
The blend doors are vacuum actuated. You most likely removed or capped off the vacuum source for the HVAC system. A factory vacuum diagram will show you which line was for the HVAC and where it's vacuum source came from.
Old 03-18-2009, 02:44 PM
bigti99a's Avatar
same issue here. there is a little black peice that has 3 vaccum lines coming to it by the pcm. i found that one of those was broken. i would start there.
Old 03-18-2009, 04:02 PM
Well i found a vacuum line on the very back that wasnt hooked up so when i get done hooking my clutch rod back up ill test it out.
