Flexplate & Cooler Install Questions!!!
Old 03-18-2009, 02:55 PM
XxApollynxX's Avatar
Default Flexplate & Cooler Install Questions!!!
Been searching can't find anything I just picked up a SFI Flexplate
Didn't come with any new hardware my question is should I re-use my stock bolts???
Also does any body know what the torque spec are for the flexplate bolts?
And is there any sequence to follow?
On the transmission cooler should I run it inline to the factory cooler in the radiator or just remove the lines from the radiator and use only the aftermarket cooler???
If I remove the lines should I plug the radiator with NPT fittings or leave them empty!!?!?
Thanks so much in advanced!!!
Old 03-18-2009, 04:14 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
http://www.texasfbody.org/TorqueSpecs/
I torqued mine the same way as a wheel
Can't help ya on the cooler, I'm running a TH350 and a stand alone cooler
Old 03-18-2009, 05:35 PM
So I should buy new ones or I can re-use the stockers?
Old 03-18-2009, 09:25 PM
chevyz2801's Avatar
I reused the flexplate ones and one broke so i got it out and went with ARP.
Old 03-20-2009, 12:13 AM
Any tips on the cooler install?
Old 03-20-2009, 12:34 AM
00_Z-28's Avatar
What size is the cooler? you can run it alone if its big enough but i tied mine into the existing output line of the radiator.
Old 03-20-2009, 10:17 AM
PontiacFan's Avatar
Ask yourself, ..., Why would you NOT want to take advantage of having both the stock OE/radiator/cooler, AND the aftermarket cooler after that?
Old 03-20-2009, 11:42 AM
Wow, that makes sense I didn't think of it like that.
I got the B&M #70264 - The 24,000 GVW Trans Cooler.
