Arp head bolt torque???
I've tried doing a search and calling arp and no luck...arp is closed ...does anyone KNOW the torque specs on the arp head bolts...
85 with bolts dipped in motor oil 10w 30
you should cycle them through several times by cracking thme loose and re tightening one by one ijn order to get all of the initial stretch out if they are new.
It will help keep you from have to do it after you start it for the first time
