Compression/Leak Down Test
Old 03-21-2009, 12:36 PM
BigEd_98Formula's Avatar
Default Compression/Leak Down Test
The compression test doesn't matter, just as long as all numbers are w/in 10% right?
The leakdown should be a specific number right?
Just curious what kind of numbers i should be looking for when I do these tests on my LS1.
Thanks,
Ed
Old 03-21-2009, 01:00 PM
SweetS10V8's Avatar
5%-10% or less typically for leak down is an engine in very good condition. engines with more miles in fairly good condition can have up to 20%. Anything past 30% will be an issue.
The great thing about leak down is you get to see where its going. (Past rings, intake valve, exhaust valve)
