Diagnostic Port
Old 03-21-2009, 05:54 PM
TABBED 5.3's Avatar
Default Diagnostic Port
What would cause my diagnostic port to not work. SES light came on recently, and when I hook up my scanner, the scanner does not come on. However, it sounds like the fuel pump is priming while it is plugged in. The car is a 96 OBD 2, and has a mail order tune. Also I have checked all the fuses. any suggestions?
Old 03-21-2009, 05:55 PM
RamAir95TA's Avatar
Do you have the correct cable and software?
Old 03-21-2009, 06:06 PM
TABBED 5.3's Avatar
As far as I know, I'm using a regular OBD2 scanner, I know it works, because I tested it in my truck.
Old 03-21-2009, 06:12 PM
RamAir95TA's Avatar
This might sound silly, but perhaps the DTC you're getting is FOR the diagnostic port.
Sorry I don't have much more to add, being that I'm OBDI.
Old 03-21-2009, 07:05 PM
bombebomb's Avatar
This is a shot in the dark and since you said the fuel pump is priming I am going to guess this will not be helpful. Anyways, does the key have to be turned on?
Old 03-21-2009, 07:54 PM
shbox's Avatar
Make sure your cigarette lighter fuse is good. It also provides power to the DLC, pin 16.
Old 03-21-2009, 11:50 PM
doug1105's Avatar
just a thought- maybe check the pins on the scanner plug to make sure none are bent.
Old 03-22-2009, 05:13 PM
explicit.muscle's Avatar
I had the same problem, and it ended up being the ground wire that hooks on to the coil bolts that was left off.
Old 03-22-2009, 07:48 PM
shbox's Avatar
I another forum, I think he found the answer was the fuse.
Old 03-22-2009, 08:02 PM
TABBED 5.3's Avatar
yep, it was the fuse. Me being the jackass that I am did not realize it was the same fuse as the cig. lighter. thanks to everyone who replied / helped in this thread.
Quick Reply: Diagnostic Port
