Broke my E-cutout switch (QTP)
Yes, I replaced the switch that it came with because it was a bit too big to fit horizontal in the ashtray. I got a smaller one at Lowes in the electrical dept.
Its a "dual pole dual throw switch"
Did you check the fuse? How did you power the switch. Mine is connected to the cigarette lighter and I can't plug anything in there or it will blow the fuse...
I had to get the fuse at Radioshack
Check that first
Edit: damn you must have Superman strength. Were you man handling that switch lol.
Mines been fine for 18+ mons
Check that first
Check that first
Check that first
If I'm feeling adventurous, I might create an on/off switch for my seat controls (if i cant find a switch thats spring loaded in the middle). This way, I could shut it off and if I hit the switch, it doesnt break the cutout. Side advantage is that people couldn't **** up my seat adjustments.
Check that first
Check that first
