Shift Solenoid Problem
Old 03-22-2009, 01:47 PM
InsaneDomestics's Avatar
Default Shift Solenoid Problem
I have a 4L60E Trans in a 98 Camaro and I was wondering if the Shift Solenoid would make my car not move and would it make my Trans not PUMP??? Thanks! (Im getting a Trouble Code about Shift Solenoid Stuck Off and something about TCC) Any Ideas?
Old 03-22-2009, 03:50 PM
Closed ex-Sponsor Account
tptransmission's Avatar
No if you have no pressure then you have bigger issues. Did you remove a cooler line or put a gauge on to check pressure?
Old 03-22-2009, 03:52 PM
Yeah I removed the lines and I had nothing. Pump is bad then huh? Well I picked up a Powerglide the other day for $100 so Ill throw it in there.
Old 03-22-2009, 03:57 PM
LS1Tech Sponsor
performabuilt's Avatar
Yep you have a bad pump. 2 speed power glide in a street drive car?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-22-2009, 08:22 PM
Yep, whats wrong with that? I had one in my 66 Chevelle that I drove everyday and I loved it.
Old 03-22-2009, 08:28 PM
LS1Tech Sponsor
Nothing I dont guess if gas milage, engine wear are of no importance. They do work well enough.
__________________
Call 888-744-6542
Old 03-23-2009, 08:52 AM
big wally 55's Avatar
How hard can you throw ??????
