can i swap a cassette monsoon for a monsoon cd one?
i know the better choice would be to install a better hu, but want the stock look, are they interchangable? i couldnt find an answer in the faq or search.
thanks
josh
thanks
josh
Ungrounded Moderator
Yes, they are interchangeable. Just make sure you get one from the same model of car so that it matches the dash.
And yes, it was covered in the Monsoon FAQ:
The head unit is nothing special - it's just an ordinary 1.5 DIN Delco radio with a Monsoon label on it. In fact, some of the early Monsoon systems didn't even have the label on the head unit. Camaro HUs are black with black controls and blue/white illumination. Firebird HUs are dark gray with gray controls and red illumination. Both types are basically the same and are physically interchangeable although they had some different features - Camaros came with speed compensated volume whereas Firebirds have a graphic equalizer. Both are capable of using a power antenna but only the Firebirds came with one.
