Car running like poo
My car has been sitting for about 2 years, fired it up yesterday after installing new opti (AC Delco), plugs, wires, MSD coil. Car runs like *******, there is no arching with the wires and they are not touching the headers, i made sure of this, car sputters and sounds like ***, almost like its running rich. Im suspecting the O2 sensors personally, because I have open headers and think 2 years of being out in the open could have fried them.
I put in fresh gas as well, so I don't suspect the fuel to be the problem
Update: Ok, my belief now is that it is problems with my lifters, loud ticking noise coming from valve train on both sides, oil pressure does not move when car is revved.. normal? Oil pressure is steady at about 38psi
Here is vid shot today.. not good sound quality, hard for you to hear it *coughing* but you can hear the ticking.. clearly it is something with valve train:
What you guys think? car has been sitting for 2 years so I wouldn't doubt stuck lifters.. that would cause the car to run bad correct?
yea i will double check that, possible the coil or ICM maybe? (can autozone check ICMs?) I realize it an be a lot of things, but its backfiring as well once u rev and let off the throttle, it always did every now and then espcially with open headers, but its bad now
yea like i said i will double check tomorrow, and if it still is, i will post a vid... i gotta get it running right, its almost spring and my trans is almost done
