Comp "R" lifter preload setup?
I am about to measure for the correct pushrod length and was wondering if anyone had some helpful hints on the preload for comp r lifters. Comp's site says .002" to .004". There is not a big range here. How would I precisely measure for this? Do I have to have preload set correctly to get proper pushrod length?
Copied from their web site.
Any ideas?
DESCRIPTION:
Pro Magnum Hydraulic Roller Lifters
Chevrolet Small block. For use in blocks originally equipped with hydraulic roller cam. 1987 to present, and GEN III, LS1, LS2, and LS6.
COMP Cams® Pro Magnum Hydraulic Roller Lifters™ are specifically designed to perform at higher engine speeds. When engines are equipped with a hydraulic camshaft, high rpm is limited by the improper position of the internal piston as the lifter inevitably "pumps up". This improper location results in open valves and therefore leads to lost power or sometimes even engine failure. NOTE: These lifters require an adjustable valve train (check here for adjustable valve train components), and must be pre-loaded to .002" to .004" for proper operation!
