Comp "R" lifter preload setup?
Old Mar 23, 2009 | 11:44 AM
2manytoys's Avatar
Default Comp "R" lifter preload setup?
I am about to measure for the correct pushrod length and was wondering if anyone had some helpful hints on the preload for comp r lifters. Comp's site says .002" to .004". There is not a big range here. How would I precisely measure for this? Do I have to have preload set correctly to get proper pushrod length?
Old Mar 23, 2009 | 11:47 AM
WKMCD's Avatar
I would think .020-.040
Old Mar 23, 2009 | 02:14 PM
2manytoys's Avatar
Copied from their web site.
DESCRIPTION:
Pro Magnum Hydraulic Roller Lifters
Chevrolet Small block. For use in blocks originally equipped with hydraulic roller cam. 1987 to present, and GEN III, LS1, LS2, and LS6.
COMP Cams® Pro Magnum Hydraulic Roller Lifters™ are specifically designed to perform at higher engine speeds. When engines are equipped with a hydraulic camshaft, high rpm is limited by the improper position of the internal piston as the lifter inevitably "pumps up". This improper location results in open valves and therefore leads to lost power or sometimes even engine failure. NOTE: These lifters require an adjustable valve train (check here for adjustable valve train components), and must be pre-loaded to .002" to .004" for proper operation!
Any ideas?
Old Mar 23, 2009 | 02:35 PM
Taphee6's Avatar
Just make sure you do it right. OR
Old Mar 23, 2009 | 07:00 PM
SweetS10V8's Avatar
.002-.004 is probably about 1/16th of a turn past zero lash.
Old Mar 24, 2009 | 01:20 AM
moeZ28's Avatar
With stock rockers, and a TREX V2, I put 0.020" preload on my comp R's, and had the quietest LS valve train anyone had ever heard! No noise whatsoever!
I also made over 490 rwhp with that 348ci LS1 setup.
Old Mar 24, 2009 | 04:54 AM
vettenuts's Avatar
Any ideas?
I think you answered your own question. They are too hard to set with pushrod length and Comp recommends an adjustable rocker. A lot of guys seem to run them deeper then Comps recomendation.
Old Mar 24, 2009 | 06:44 AM
2manytoys's Avatar
I have adjustable rockers. My heads are milled so that is the reason for pushrod length check. I think I will try .020" as I will not be revving it to extremes.
Old Mar 24, 2009 | 08:51 AM
moeZ28's Avatar
Oh, and I shifted at 7000, rev limiter set at 7200...
Old Mar 24, 2009 | 11:13 AM
Taphee6's Avatar
Someone please tell me how you checked the .020 preload. Please dont give me the 1/4 turn, 1/2 turn from 0 lash.
Old Mar 24, 2009 | 11:19 AM
vettenuts's Avatar
What type of adjustable rockers? A stud mount adjusts differently than one with the adjustment threads directly over the pushrod.
Old Mar 24, 2009 | 02:09 PM
2manytoys's Avatar
I have Comp rockers ( stud adjustment type). I am thinking I could set up my dial indicator on the rocker arm above the pushrod and go 1/4 turn past zero lash and get my measurement that way.
Old Mar 24, 2009 | 04:07 PM
vettenuts's Avatar
Assuming a 3/8-24 thread on the stud, that is approximately 0.017".
