Pic of my new LT1 :D
After waiting a long month my new LT1 is here. Spec sheet will be on here soon but it has a ported intake, better cam/crank and obviously the shorties (wanted to stay legal). Everything should be put back together by the weekend, and hopefully the TSP Rumbler will go on monday. Expect a sound clip soon.
When is it going in?
Here are the specs. Its nothing too exciting, a stock rebuild with some minor mods.
Cylinders Bored .20 over
Pistons/piston rings .20 over
Cylinders honed
Crankshaft ground 10/10
ISKY 235D performance springs w/ dampner
Intake ported to 58mn
Intake ports hand opened
Edelbrock Shortie Headers
everything else is just stock, but new
the cam specs are:
Lobe Center:116 deg
INTAKE TIMING:
Duration: 257
Cam Lift: .310
Valve Lift:.467
EXHAUST TIMING:
Duration: 265 deg
Cam Lift: .323
Valve Lift: .485
Duration:
Cylinders honed
the cam specs are:
Lobe Center:116 deg
INTAKE TIMING:
Duration: 257
Cam Lift: .310
Valve Lift:.467
EXHAUST TIMING:
Duration: 265 deg
Cam Lift: .323
Valve Lift: .485
Duration:
