Question on rust, cracked plastic, Headlight motor grinding
I was looking at buying a trans am and the exaust tips are rusting and i was wondering what i could do about them. I do not have any pics tho srry
Also there is come plastic that is cracked by shifter. When I shift it the whole plastic moves. Its cracked like 2 inches so its all the way through.
The lights go up and down fine but the drivers side one makes a grinding noise when its fully down for like 2-3 secs after its down. Is it just the sucky plastic gear or something else?
Thanks guys
Thanks guys
Replace the tips, The shifter plastic that connects to the boot? That can be replaced easily. And yes it is a plastic gear... they all will go out eventually, Someone make a Brass or aluminum replacement search for it on the web it is out there, maybe ebay.
its just to the right of the shifter by like the outlet plug thing. i think it has a shift kit and he said someone broke the plastic going into reverse.
and the exaush i think is stock also so there are no tips sorry so could i polish/rust remover them to make them look a little better?
