Which stock tables to use going to 28lb injectors
Alright starting with a 99 which of course has 26lb injectors.
Swapped in some stock 28lb injectors.
Well the 98 and 02 flow rate vs KPA tables are the same so I swapped them in to my 99's tune.
What about the offset vs volts vs VAC, the FA multi stage 1 vs time, the boundary and short pulse adder.
Should I copy these tables to my 99 and if so which do I pull them from, the 99 and 02 don't match on these tables
