Drag Racing Tech
Automatic shifters- detent, gate, ratchet ...
Old 03-27-2009, 02:53 PM
Skinny's Avatar
Question Automatic shifters- detent, gate, ratchet ...
What's the difference??
I'm looking for a shifter for a manual VB TH350 that will allow me to "hit" the shifter one time to shift from 1st to 2nd, without worrying about overshooting into 3rd. Then smack it again to shift from 2nd the 3rd, without worrying about throwing it into neutral. So what kind of shifter do I need?
Old 03-27-2009, 03:20 PM
AgFormula02's Avatar
pro rachet is what I use. Bang it once for second, bang it again for third. In a regular valve body, the pain is that from neutral you have to ratchet down to first. (3 slaps from neutral)
BTW, itr is advised not to go from 3rd to neutral at the end of the run.
Old 03-27-2009, 03:32 PM
LS1Tech Sponsor
MADMAN's Avatar
We use Precision Performance shifter. They are the best out there for a 3 speed.
http://www.precisionperformance.com/home.htm
__________________
www.madmanandcoracing.com
225-343-9029
Old 03-27-2009, 03:52 PM
LS1SpeedAddict's Avatar
Great for 2 speeds as well, we have one in my dads dragster and we love it. When I switch to a powerglide this is the shifter I will use.
Old 03-27-2009, 04:15 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Running a Pro Ratchet here as well
Old 03-27-2009, 04:38 PM
camscam02's Avatar
what makes them the best out of curiosity? above the pro ratchet or hurst quarter stick?
I see everyone likes them so i was wondering why?
Old 03-27-2009, 05:45 PM
Skinny's Avatar
Thanks for the recommendations everyone, but I'm still confused as to what the differences are in the gate, detent, and ratchet mechanisms. I see the hurst quarterstick is a gate style (according to summit) and the pro ratchet is a ratchet (obviously). So what's the difference? I understand how the ratchet works (I think), but would the design of the quarter stick allow me to overshoot the 1-2 shift and put it in 3rd, unlike the ratchet?
Old 03-27-2009, 07:40 PM
crashinaz's Avatar
Gate - Couple diferent styles Winters/Cheetah/Art Carr requires two motions to select a gear (side and back or side and forward, whichever the case may be)... On the Pro stick/Quarter stick style shifters it's a push or pull from 1st to 2nd, a slight trigger pull combined with a push or pull to 3rd... So to answer your question... No. You need to actuate the trigger to get 3rd.
Detent - Pretty much like most a factory type shifter. You can feel the indexes for the gears, but nothing stops you from going from 1st to 3rd in one motion.
Ratchet - Once you pull the shifter back into your forward gears, the handle stays in the same spot. Each time you push or pull the shifter it changes 1 gear, and 1 gear only, then springs back.
The whole idea behind the gate and ratchets are to prevent skipping a gear or hitting neutral... And of course the obvious safety lockout of reverse. SO in closing, what you are describing is a ratchet shifter.
Old 03-27-2009, 08:07 PM
LS1Tech Sponsor
MADMAN's Avatar
The precision is a hit and hit styleshifter. There is no other action required. I dont like the ratchet style because it is easy to come out of adjustment.
__________________
225-343-9029
Old 03-27-2009, 08:22 PM
SmurfLSX's Avatar
i too have the precision performance shifter and highly recommend it. Its awsome
Old 03-28-2009, 11:16 AM
ndfrsd6's Avatar
b&m ratchet here
Old 03-28-2009, 01:37 PM
firefighting1101's Avatar
i waas gonig to go with a Turbo Action Cheetah, because i thought that the gate style would be a little more street friendly than a ratchet style.
Old 03-29-2009, 07:35 PM
Randy WS6's Avatar
I use the Hurst Quarter Stick Gate. Very nice shifter
Old 03-30-2009, 06:33 AM
Krazy98Z28's Avatar
I also run the hurtst quarter stick with the pistol grip. Mine is reverse MVB so I pull for 2nd then squeeze the lever and pull 3rd.
Old 03-30-2009, 07:48 AM
Skinny's Avatar
I really need to get my hands on a Quarter stick I guess. I'm kind of torn between that and the Cheetah. I think the ratchet style might get old for me real quick, noting Madman and AgFormula02's comments. The only thing I'm really concerned about is going for 3rd and overshooting into neutral. For the Cheetah my concern is how well it can handle "abuse" by my banging gears. It's mostly plastic, correct?
Old 03-30-2009, 03:24 PM
GTFORMULA's Avatar
I have the B&M pro ratchet and there is no possible way you can over shift it. You tap it up and it stops.. then you tap it again and it stops again. Very easy to use.
Old 03-30-2009, 04:38 PM
Camaro396's Avatar
I have a B&M Carbon Composit X ratchet shifter. Love it.
Old 03-30-2009, 05:53 PM
crashinaz's Avatar
IMHO, the ratchet is easiest to drive on the steet with a mvb/rmvb. Ya just slap it around... Granted it's a pain on a standard mvb to go from 1st to park... Which you have to do pretty much every time you enter a parking lot and park.
Quick Reply: Automatic shifters- detent, gate, ratchet ...
