M6 to 4l80 speedometer ?????
Old 03-29-2009, 09:32 PM
Randy WS6's Avatar
Default M6 to 4l80 speedometer ?????
I installed a 4l80 in my 2000 TA witch was a M6. The speedometer pluged right up. I have 4:30 gears, At 35mph ,my speedometer reads 85mph. I have EFI Live. What are you guys doing to off set the 4L80
Old 03-30-2009, 11:13 AM
ShevrolayZ28's Avatar
I think it can be done with EFI Live. But on my car I am using a Compushift controller so I decided to use a Dakota Digital SGI-5c speedo signal calibrator.
https://ls1tech.com/forums/automatic...o-cal-box.html
This would work for you too....
Old 07-23-2010, 09:30 AM
ArklaTexan's Avatar
http://www.dakotadigital.com/index.c...rod/prd126.htm
Old 07-23-2010, 09:51 AM
Jays_SSZ28's Avatar
You need to tune it for a 40 tooth reluctor wheel.
And the rear gear, tire size. Make sure it's plugged into the rear sensor.
