Purge question
Purge question
Alright this is probably a complete noob question but I've tried using the search with no luck. How do you get the nice white cloud basically for show with the purge?
So you dont have to have a bigger line for the purge to allow more flow or anything? I have the hsw kit and purge but it just sprays a light burst at 1000psi. I dont just hold it down forever, is that what your saying just hold the purge down and there ya go?
What size is your purge line? I noticed my line from nitrou dave was tappered down at the end. After I cut the line to lenth I had more of an opening. Other than that you just need nitrous in the line and bottle pressure.
are you going with a single outlet ? If you are going with a dual you need the line to be 3/16 to the Y and 1/8 out . Thats what i do on the most systems i do if you need to adjust the angle of the outlet take a drill bit that will fit inside of it and you can bend it some for fine tunning. Copper line is what most use on the 1/8 side
