Western Members CA, AZ, NV, UT, CO, NM, HI
Just Wanted Say Hello.....with pictures.
Old 04-01-2009, 01:34 AM
vegasse's Avatar
Default Just Wanted Say Hello.....with pictures.
Quick background. I've owned 4 TA's, only one LS1 2000. The others were an 80 turbo TA, 94 Formula, and 95 Firehawk. I'd REALLY like to buy another one here shortly, just need to find the right one. Anyway, just so you don't think I'm some newbie with no sense of cars, here are a few of my rides.
This is one of only 43 Overfinch made Range Rover Sport Supercharged for 2007.
Overfinch tuned supercharged engine making 500 horsepower
Overfinch 22 inch rims with Pirelli P-Zero Scorpion 295/30/22
Overfinch Spoiler, Overfinch body kit
Overfinch Exhaust with chrome exhaust tips
Blacked out tail lights
smoked side markers
tinted windows
Body color side vents
honeycomb grill, deep sculpt front and rear bumpers
Brembo brakes
dynamic response suspension
Santorini Black Metallic exterior
Ebony premium leather heated seats
Walnut wood accents
Rear seat entertainment system with dual headrest tvs
14 speaker 550 watt Harmon Karden Logic7 surround sound stereo with subwoofer
electronic rear differential lock
adaptive cruise control
Land Rover alloy valve stem caps
clear bra
and a few other things I am sure I'm forgetting.
vegasse's Avatar
2004 Mitsubishi Evolution 8
The Virtual Works stuff is not on the car in pics, but I will get some more. Chassis has 36k on it. Mods have less than 2k.
Engine:
Buschur Racing 2.3L Stroker
Crower Forged Rods
Crower Billet Crank
CP Pistons
Buschur Racing Stage 3 race head
ARP Studs
Fully Sleeved Block by Darton
ARC Gradient Spark Plug Cover
ARC Radiator Cooling Panel
Ralliart Spark Plug Wires
Billet Timing Tensioner
HKS DLI 2 Ignition Amplifier
HKS 280/280 Cams
HKS Adjustable Cam Gears
Fuel:
Virtual Works Racing Aluminum Intake Manifold
Dual AMS Fuel Rails
Fuel Lab Fuel Pressure Regulator
Dual RJC 1000cc Injectors
Buschur Racing Dual Fuel Pumps
4 inch Virtual Works Intake
Greddy Ti-C Exhaust System
Virtual Works Racing T4 GT35R Turbo Kit
Fullrace FMIC
PWR Aluminum Radiator
ARC 1.5 bar radiator cap
Agency Power front and side engine mounts
AEM EMS
Transmission:
Shepherd Racing Stage 1
Shepherd Racing Stage 2 Transfer Case
Exedy Triple Plate Cerametallic
B&M Short Shifter
ARC Titanium Shift ****
Kartboy Shifter Base and Shifter Bushings
Suspension:
Tien Monoflex Coilovers
ARC Front Strut Tower Bar
Wheels:
Volk Racing RE30 18x9
Advan Neova 265/35 R18
Volk Racing Duralumin Lugnuts
Rotora Slotted Rotors F/R
Rotora Brake Pads F/R
Rotora Steel Braided Brake Lines F/R
Interior:
Rexpeed Carbon Fiber Dash
Rexpeed Carbon Steering Wheel Gauge Pod
Rexpeed Carbon A-Pillars
Kenwood DNX8120 indash Nav/DVD
Mitsubishi JDM Double Din
Orbital HVAC conversion kit
Greddy EGT + Oil Temp gauges
AEM Boost + AFR Gauges
Tyrant Carbon Armrest
EVO SE Leather/Suede Seats
Exterior:
Chargespeed Vented Carbon Hood
Chargespeed 20mm Fenders
Chargespeed Carbon Vortex Generator
Chargespeed Type 1 sideskirts
Chargespeed Type 1 front bumper
Chargespeed Type 1 rear bumper w/ carbon fiber diffuser
Mitsubishi JDM Headlights
Mitsubishi Smoked Taillights
Smoked Side Markers
Dafarmer LED License Plate Light
Rexpeed Carbon Mirror Covers
Apex Silver w/ slight blue pearl in paint
Evo XI Wing
Car made 695awhp on q16
Old 04-01-2009, 01:35 AM
vegasse's Avatar
2003 Mustang Cobra
28k Miles
No accidents, clean title
Freshly painted in flat black
Certified 12pt 8.5 cage powdercoated black
Stock seats and interior
Fully built 5.1 Stroker by Lawless Engines
380cfm Lawless ported heads
Fluidyne radiator
Maximum Motorsports complete front k-member package
Kooks 1 3/4x3' headers jet hot coated
Kooks 3' x pipe
Sullivan intake
Sullivan fuel rails
Upper adjustable clutch quadrant
Weapon x cop ignition set
Sieman deka 63lb flow matched injectors
Accufab single blade throttle body
Fore precision billet fuel hat W/ SINGLE 8an line
Complete fuel system with 8an line front to back all with black earls an fittings
Mcleoud street twins clutch
Twin Ford gt super car fuel pumps
Flamong river steering shaft
Dual fuel pump driver moduals
Procharger f1 cog pulley set up
Viper spec tranny from d&d motorsports
Billet shafts
Cryo treated gears
Virtual Works Racing custom intercooler set up
........and 100 other things I will list when I go through all the receipts on Friday.
Old 04-01-2009, 01:36 AM
vegasse's Avatar
Engine:
Virtual Works 3.4 stroker
CP Flat Top Pistons
Carillo Rods (upgraded carr bolts)
Crower Balanced Billet Crank
Clevite bearings
Program Billet mains
Line honed block
Fully polished and ported Virtual Works race head
Competition Copper Alloy valve seats
Five angle valve job
Ferrea dual valve springs
Ferrea titanium valves +2mm
Ferrea titanium retainers
Ferrea valve keepers
Ferrea spring seats
Ferrea spring locaters
Ferrea valve guides
ARP L19 Head studs
HKS 280 Cams
Unorthodox Cam gears
Unorthodox Pulleys
BoostLogic crank pulley
BoostLogic Billet tensioner
Virtual Works Dual Rail 12 injector Intake Manifold
Accufab 95mm Polished Throttle body
Virtual Works 8 ½ Quart Aluminum Oil Pan
Virtual Works Modified Pickup for Deep Pan
Virtual Works Modified Oil Pump
Virtual Works Modified Water Pump
Toyota P/S pump (new)
Power Enterprises Kevlar Timing belt
Power Enterprises Kevlar Serpentine belt
Chromed Valve covers
Powerhouse Polished Spark Plug Cover
TTC Polished Brake Cap
TTC Polished ABS Relay Cover
Greddy Billet Oil Cap
Virtual Works Aluminum Fuse Box Cover
Virtual Works Breather with custom 1/1 Can
All Cosmetic Bolts Switched to Stainless Allen Bolts
Lines Converted to Braided
Polished + Black Fittings
Extensive Chroming
TRD motor mounts
High Output Chromed Alternator
New Engine Harness
Engine entirely stripped, holes welded, brackets ground, painted + cleared
Aluminum Belly Pan
Turbo + Exhaust:
Virtual Works coated turbo header T6
Tial 44mm wastegate
GT47-88mm Dual Ball Bearing turbo (polished and coated) T6
Virtual Works anti-surge turbo insert
Custom SP (chromed) 6” cold air intake
K+N 6 Inch Race Filter
Virtual Works Modified water neck (to fit large frame turbo)
Virtual Works 4 inch stainless coated downpipe
Virtual Works 4 inch stainless coated midpipe
Sound Performance 4 inch stainless electric exhaust cutout
HKS racing bov
HKS 4 inch Hiper Titanium Exhaust
Cooling:
PWR Brushed Aluminum radiator
Virtual Works Custom Brushed Aluminum Dual Fans (6000cfm)
Sound Performance 5 inch race Intercooler
Custom Virtual Works 4” polished intake piping
Virtual Works Polished Upper and Lower Intercooler Straps
TRD Thermostat
Virtual Works Upper radiator hard pipe chromed
Virtual Works Lower radiator hard pipe chromed
Virtual Works Upper radiator cooling plate chromed
Upper Radiator show plate chromed
Virtual Works custom 1/1 Aluminum Overflow can
Trans + Clutch:
New V160 6-Speed Transmission
Tilton Carbon Triple Disc clutch
Custom 1pc steel driveshaft (cnc’d ends)
Virtual Works Driveshaft Loop
TRD LSD
TRD Trans Mount
Virtual Works CnC’d Aluminum shifter bushings
C’s Short Throw Shifter
Strain gauge
Fuel System:
Weldon 2835 Fuel Pump
Weldon Fuel Pressure Regulator
Virtual Works Dual Fuel Rails w/12 1000cc Injectors
Bosch 1000 high impedance injectors
Custom AN Fuel Lines
Suspension:
Virtual Works custom rear suspension
Virtual Works mini tub
TRD Sway bars (Ceramic Coated Silver)
Cusco carbon rear strut bar
DoLuck Cross Bar
Tein Flex coilovers front (spun on lathe to remove green to show spun aluminum)
Koni coilovers w/Eibach springs rear
Tein EDFC controller
Titan Billet mount kit
Extended Rear Studs
Electrical:
Motec M800 Engine Management
All Motec Sensors and upgrades
HKS DLI Twin Power Ignition
Blitz turbo timer
AEM Boost Gauge
Defi Water Temp + Oil Pressure Gauges
AEM Serial Gauge
FJO Wideband gauge custom mounted
TRD 10K Tach
Optima Trunk relocated battery
Brakes:
Brembo 14 Inch Big Brake Kit Painted Lambo Verde
Slotted front + rear Brembo rotors
Goodrich Stainless brake lines
Wheels + Tires:
HRE 597R 18X10 front
HRE 597R 18X12.5 rear
Mickey Thompson ET Street Drag Radial (345/35/18)
BFG Gforce ZR front (265/35/18)
Interior:
TRD Black Steering Wheel
TTC Drilled Performance Pedals
10% Tinted Windows
New Carpet 33,000 miles
New Factory OEM mats
New Factory Black Leather seats
SP Rear Seat Delete
Exterior:
Genuine DoLuck Late Model Front Bumper
Genuine Bomex side skirts
Genuine TRD Hood
Genuine TRD Wing
Clear Signal Markers
Smoked Side Markers
Smoked Taillights
Smoked Third Brake Light
3M Clear Bra
Performance:
Tuned by Mike Angel of Factor-X
RWHP: 1418
RWTQ: 1008
Here it is with the stock hood/carbon wing on. I'm not sure which wing/hood set up I'm going with for sure. Most likely put the genuine TRD hood/wing back on the car.
Old 04-01-2009, 01:40 AM
vegasse's Avatar
2006 Gallardo SE special edition. There were only 250 of these made, and only 4 made with e-gear in Verde from what I am told. The car has well over $100,000 in modifications and $30,000 paint on top of the price of the actual car. This car has been 100% done by Heffner Performance in Sarasota Florida. For those of you who know modified Lamborghini's, Heffner is the class of the industry. The engine has been entirely removed and built bulletproof.
This vehicle makes over 1300awhp on race gas, 1016awhp on 100 octane pump gas. Now remember, this is WHEEL horsepower, not flywheel horsepower like the OEM's advertise. If you want a flywheel number, this car makes over 1500hp. You can also go back to a pump gas set up where the car makes 880awhp. The great thing about this car is that it retains all driveability. It drives just like stock until you get into the boost. If you want to leisurely drive it around town, you can, or if you want to push it and beat pretty much everything on the road, this is the car for you. It will go 0-200mph in UNDER 1/2 mile. It will do 0-60 in under 3 seconds and 0-100 in just over 5 seconds. A Veyron will be a spec in the rear view in this Gallardo.
Mods.............
Engine Removal and Disassembly -
L.A. Sleeve Steel Cylinder Liners -
Carrillo Forged Rods -
Custom 9:1 CP Forged Pistons -
Polished Crank Journals -
Clevite bearings -
Balancing and Blueprinting of Engine -
Heavy Duty Clutch and Pressure Plate -
Twin Water Cooled Dual Ball Bearing Garrett 67mm Billet Wheel Turbos -
T04 S compressor w/72mm inducer
Garrett T4 four bolt discharge housings w/82 A/R ratio -
Two Tial 44mm wastegates -
Two Tial 50mm Blow Off Valves -
Custom Made Stainless Steel Turbo Midpipes -
Custom Made Stainless Steel Turbo Downpipes -
Custom Made Stainless Steel Exhaust System -
Stainless Steel Turbo Oil Feed Lines -
Stainless Steel Turbo Oil Drain Lines -
Colder Heat Range Spark Plugs -
High Flow Turbo Air Inlet Plumbing -
High Flow Turbo Air Discharge Plumbing -
Spearco twin Water to Air Intercoolers -
Water Pump -
Intercooler Water Reservoir -
All Braided Lines and Fittings -
255 lph in tank fuel pumps -
Upgraded Fuel Injectors -
K&N conical air filters -
Upgraded Gaskets and Fluids -
Upgraded Halfshafts -
AEM EMS -
Dual Maps controlled by switch -
Genuine Lamborghini OEM Superleggera Carbon Rear Diffuser -
Carbon Decklid -
Larger Brembo Rotors -
Full Body Clear Bra by Pro-Tech (over $5000) -
15% tinted windows -
Ceramic windshield covering -
K40 Calibre In Car Laser/Radar -
HRE 843R w/Textured Monoblock Finish -
Hoosier A6 315/30ZR19 rear -
Hoosier A6 235/35ZR19 front.
The vehicle had some rock chips on so before putting on the full body clear bra, it was ENTIRELY repainted the factory color. Brand new engine and twin turbo system have less than 600 miles!!! This car is basically BRAND NEW!
Old 04-01-2009, 01:47 AM
Soul TKR's Avatar
holy ****...
Old 04-01-2009, 01:54 AM
C5natie's Avatar
Is this a Gone In 60 Seconds remake? LOL. Wow, really sweet collection you have there. Nice to see some sweet Imports done right, not over the top. That Supra must be a beast on the hwy! 1400+rwhp!! Do they just deliver tires to you every week?
lol.
vegasse's Avatar
Originally Posted by Soul TKR
holy ****...
I get that sometimes. I just wish someone would post a fully built engine, no accident, clean title, 6-speed, low mileage, modded out, black/black 98-02 WS6 I could buy. It seems to be QUITE an elusive series of criteria these days in cars for sale.
Old 04-01-2009, 01:55 AM
C5natie's Avatar
BTW, hello and welcome to the site. What the hell you do, rob banks for a living?
Old 04-01-2009, 01:56 AM
vegasse's Avatar
lol.
It actually hooks believe it or not. The mini tub and custom rear suspension made all the difference in the world. I'll post a dyno vid when the car hits the dyno again in a couple days. The car squats so hard rolling into boost in 2nd that it feels like it's a jet taking off.
Old 04-01-2009, 01:58 AM
C5natie's Avatar
Awesome! Wow, cant wait for the vid. Thnx for sharing.
Old 04-01-2009, 01:59 AM
vegasse's Avatar
Thank you sir. Now I just need someone to sell me the RIGHT WS6 so I can get back in the GM game.
Old 04-01-2009, 02:01 AM
Soul TKR's Avatar
I bet you do!!!!! For crying out loud!!!
Old 04-01-2009, 02:03 AM
oChristiano's Avatar
You just reminded me how poor I am.
Lol, Welcome, badass collection.
Any chance I could get a ride next time I'm in Nevada????? LOL Jk.
Old 04-01-2009, 02:24 AM
carbonfiberbird's Avatar
AAAAHHHHH!!!!!
Dude you have a BADASS collection that Overfinch stuff is expensive as hell, my cousin works on only imports, just like the cars you have except for the supra. And he has told me how much some of his customers spend, its crazy but if I could do it I would too!
Old 04-01-2009, 03:36 AM
94'BLKBRD's Avatar
Old 04-01-2009, 11:38 AM
vegasse's Avatar
Thank you gentlemen, and no that's not my girl. Just a friend.
Old 04-01-2009, 11:51 AM
hlaalu's Avatar
nice. are you ever at cars and coffee?
Old 04-01-2009, 11:58 AM
vegasse's Avatar
I've gone twice. FAR too early in the morning for a Saturday in Vegas. Stay tuned, we are going to be starting something new soon.
Old 04-01-2009, 12:00 PM
Thepheroe's Avatar
U make me feel poor but u ballin!!!!!
Quick Reply: Just Wanted Say Hello.....with pictures.
