GM carb manifold or edelbrock?
I am doing a carb setup and was wondering if anyone has experience with either the GM or Edelbrock for the LS1. Any input is appreciated!
Location: Your girl's back door giving her the long stroke while you're at work
I've got a Victor Jr on my car. I would recommend painting or powder coating it before you put it on. Fits good and uses stock LS1 style intake gaskets
They all need internal work to do their best job. Ask your head/manifold person which he prefers. I wouldn't let original manifold cost make the decision one way or another. The modification could cost more than the manifold.
Gm intake has a better casting on the inside the edelbrock you usually have to do some minor porting to get some of the shitty casting out. Wish I had some pictures but either manifold works great. I think the edelbrock has bigger ports but not by much it's been a wile though.
i ran a gm manifold after waiting almost 8 months for edelbrock to re-start casting some more victor jnrs. the batches they made were all having issues and couldnt be released at the time, so i gave up waiting. the gm fits very well and works fine.
i have the vic jr intake, it cracked on the lower side of the port, looks like where they cut out for the tab on the gasket, #1 & 3, weak point-others had the same problem-i emailed Edelbrock, said to send pics, which i did, never heard back, so i had it repaired, left a little more weld where it broke, and trimmed the valley cover a little
one thing i found, the felpro gaskets(orange) are 1/2 the price of GM's gaskets, but dont hold up, they come apart, so no bargain, the GM gaskets didnt fail
Thanks guys, good info. I have 243 (z06) heads, comp cam .581 lift, Diamond forged pistons, and will be using long tube headers. I am running a ford 9 rear end with 4.33 gears and a tremec tko600 tranny so rpm's shouldn't be a prob lol. I am pondering a little shot of NOS but haven't made my mind up yet. This motor is going into the truck in my "garage" here on the forum. Its pretty heavy, its a 1985 chevy C10 short/wide bed pickup. If I got the vic jr. port matched to my 243 heads and went to a set of AFR's later would i need to get it done again?
My first Victor JR had the O-ring recesses machined off center and they cracked but summit sent me one the next day and there will be no problems with it from what i can tell. The GMMP intake is about a 1/2" shorter from what i understand. I wouldnt see a need ot go GMMP unless i were going L92/LS7 heads, since they are the only ones out yet that fit rectangle port heads.
Edelbrock did fix the O-ring problem. I have a thread in both the Gen 3 section and conversion and hybrids section about the orings cracking with pictures.
