quick HP for my 94 Formula???
Old 04-02-2009, 02:26 PM
shocka4's Avatar
Default quick HP for my 94 Formula???
hey guys I have a 94 Formula LT1 I have a 255 lph fuel pump, a bored out throttle body, and a 3 piece cold air intake right now I was gonna do headers and a cutout next what are some other upgrades that I should go for next to get that HP up???
Old 04-02-2009, 02:28 PM
RamAir95TA's Avatar
While it won't give you more HP, a new gearset will be a huge seat-of-the-pants difference in acceleration. Sounds like you're on the right track with the headers/cutout combo.
If you're an A4, go with 3.73s. M6 go with 4.10s.
Old 04-02-2009, 02:31 PM
IronOutlaw's Avatar
100 shot and gears will make you alot faster.
Old 04-02-2009, 02:32 PM
ss.slp.ls1's Avatar
Fuel pump gives you nothing, Ported TB gives negligible gains on a stock motor, so basically all you have is a CAI. Headers and a cutout will definitely be the best mod you can do right now, should net you an additional 20rwhp. After that, you could put on some 1.6 rr's and upgraded springs. That should be good for another 10-15rwhp. Once that is said and done, you could get a 160 degree thermostat, install an EWP, and get a tune. That should cover all the bolt-ons. Then you could concentrate on a 3000+ stall (if auto) and gears (3.73's for A4, 4.10's for M6). Next consider getting some suspension mods. LCA's, PHB, some better rear shocks, and a stiffer rear sway bar will go a long way to help you hook, not to mention some sticky tires. Then...heads and cam.
Old 04-02-2009, 05:33 PM
multmigs's Avatar
x2 on the PCM tune, that should be anyone's first upgrade....
Old 04-02-2009, 09:34 PM
WhiteFormula98's Avatar
Truck Nuts will add some hp's
Old 04-02-2009, 09:47 PM
shocka4's Avatar
thanks alot so far guys that will give me a good start.
Quick Reply: quick HP for my 94 Formula???
