OBD 1 or 2? pic of car!
On my 94 Z28, I've been having trans issues. Everyone said to check the ecm for codes. Check engine light wasnt on. I jumped the 2 prongs in the aldl terminal that according to the manual, would makes the check engine light flash..the fan came on! I'm not totally new to this, I've pulled codes on my '91 K2500 truck. It has a 12 prong connector and 4 terminals inside it. Could this be obd2? My buddy I got it from said he's had it scanned before and it worked like it should have. The only thing is I've never seen an obd1 scanner that was worth anything and I thought all obd2 scanners were 16 prong. Whatcha think guys?
can anyone reccomend a good scanner to buy? Also whats a good manual? I've had the best luck with chilton manuals, a haynes came with the car..not so good.
Honestly the best way to go, if you are keeping your car for a while and want to learn more yourself, is get a cable from AKM.com and log your computer yourself on your PC using Datamaster from TTM. The cable will run you about $90 and Andew over at AKM is a great guy. The program Datamaster will give you 20 free logs and then after 20 you will need to purchase a registration code - bout $100 I believe. This will not only tell you the DTC's you are throwing but much more than a traditional scanner as you can monitor your AFR (Air Fuel Ratio), IAC counts, etc... Much better of an option. If you go this route let us know and you can post up your log so we can help you out or just tell us the DTC you are throwing.
will using this cable and using my laptop show me anything different that what the auto parts store reader whould show me? Where i live they are starting to only do obd2 based engines. all i can do now it put a jumper in and then then look in my book and guess which problem out of the few possibilities that it gives me.
I wonder sometimes....I did this on my 94 camaro several years ago...jumped the appropriate terminals and the SES light flashed the code. It was hard to the decipher the code because it pauses in between numbers.
And most auto parts stores (at least around here) do not scan obd1 cars for free only obd2.
ya i have got used to having to figure out the codes since for a while mine was always coming on. Since i got rid of all the things that kept making it come on it just stays on now. I know which one the old ones are and which one the new ones are.
I guess i need a mail order tune. But it would be really helpful to be able to plug it up to my laptop and read stuff while i drive.
