clutch/flywheel combos
What clutchs and flywheels are you using for cars with more nuts. I am running a 408 and probably capable of high tens but my POS LS7 clutch and flywheel keeps sucking ***. So what are you guys using?
Internet Mechanic
Under 500hp, but even if you spayed it, it would be fine!
Textrailia oz700 Z-grip w/ their flywheel
Tick Performance Master Cyl.
Little over 1k by the time your done but will handle the power, take off the limiter launches, and powershifts with ease since Tick uses a Tilton M/C to increase fluid to push.
