Knock sensor trouble code
I have a 95 Z28 and the service engine soon light is on so I took it to the shop and they put it on the scanner and the code that came back was knock sensor wiring harness. Not the sensor itself. So today I crawled underneath and checked to make sure the plug was in correctly to the sensor and it was. I have the ground going to an oil pan bolt so I put a test light on it and it lite up when I put the clip side on the hot wire to the starter. That means its grounding correctly right?? Does anyone have a correct wiring diagram for that area or know for sure where that ground is supposed to go? I unhooked the battery to try and reset the comp but the ses light still comes on. Any ideas or suggestions would help. Thanks
I would clean up the connector to the knock sensor and I would trace that wire all the way back to the computer and look for burns, rips, or corrosion. I'm not sure how to test it with a volt meter. Have you tried testing if for power with one clip on the connector and one clip to the block?
http://shbox.com/1/4th_gen_tech2.html#knock_sensor
The ground wire that is in the loom with the starter and knock sensor wires grounds to a lug on the block. Grounding it to an oil pan bolt should accomplish the same thing.
I don't know if this has been mentioned before, but if not I am surprised.
*I officially turn this thread back over to the OP, sorry for the hijack.
