Best converter for me? size?
3800-4000 should be a nice comprimise with either motor or spray. I'm giving a 5000 a try and probly have it tightened up but being as I already have it I figure why not try something a little on the extreme.
LS1Tech Sponsor
I would run an SST series 9" set at 4600.This is a proven converetr with your combo.Chevpower runs one very similar in an F-Body.
Give me a call or pm
Greg
1-866-726-8358
Greg
1-866-726-8358
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
i would say personally a 3800 if your going to spray, i dont know too much but i know my 3600 with a cam bigger than yours is much too small to get into the power band, but my car is NA
LS1Tech Sponsor
we run converters like this combo all the time. The SST series converter is designed to get you a high enough stall but with excellent efficiency. As long as we are 1200 away we are good.
Greg
Greg
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
Mind you, most of these recommendations are for strip only. Without saying what you plan with your car, we can only guess. Also what tires and gears do you have? You may want to only do highway rolls with it and dialy drive it, or you may be looking for only outstanding 60'. I would recommend a converter between a 3500 (nitrous use) up to a 4500 (Max ET effort for the street), on a 2.0 (hooking on street tires, efficient up top) up to a 2.4 (wheels stands on slicks, or good street manners). Talk to the converter manufacturers as they will be the best to suggest a proper converter, not forum users (who mainly have had one coneverter experience).
Chris
