Ls1 to Ls2 Swap!
Ls1 to Ls2 Swap! ( Need A Little Info Please )
Does anyone know if i can pull my LS1 out and swap in LS2 without problems? ( M6 Car)
What are known problems if any?
I have been searching awyle either im blind or... im blind.
Any info is appreciated.
Thanks guys!
Edit, okay i have found some stuff and need some more info.
Will the 58X to 24X reluctor wheel adapter by lingenfelter work so i dont have to change the reluctor wheel and cam timing gear for the LS1 to LS2 swap?
( It says it works for LS7 and LS3 but it doesnt say LS2 ) I assume it will work for LS2 aswell?
Thanks guys!
Do you have a parts list together? I am interested in knowing all the things I need to make this happen. So far I have the stuff below
Front cover with cam sensor
LS2 valley cover
wiring harness adapter
oil pan, pickup tube and windage tray
what else??????????????????????
LS2 valley cover
relocate knock sensor to side of block, get cam and knock sensor extension harness, ls2 front cover. Might have to switch the a and c pins on the cam sensor harness to work right, i did. Other than that no difference.
