ls2 to ls6 adapter harness notice
Old 04-05-2009, 09:42 AM
ChucksZ06's Avatar
Default ls2 to ls6 adapter harness notice
I recentley purchased a harness for putting ls2/fast/403 in my vette. I spent needless hours searching for something I did wrong or (this occurred while changing engines) did not hook up or crushed wire, bad grounds, etc. I just purchased this harness(casper electronics) from a reputable vendor here. I called and asked them twice if there were any problems with these harnesses. It turns out that the 6 wires that go into the ls2 tb were flipped. I changed them to the correct holes and "gee it works now" Thanks a lot for giving a damn, guys at unnamed vendor. I had a 2500.00 order in at the same time with this vendor...even spending money did not do me any good.
Old 04-06-2009, 08:24 PM
xx_ED_xx's Avatar
Nothing like expecting the customer to do quality control
Old 04-07-2009, 11:27 AM
Moderator
jimmyblue's Avatar
Well, the vendor would only know if somebody told
them. Middlemen don't get educated any other way.
Casper's might have known. Did you speak to the
source? That's where the problem should be fixed.
Old 05-05-2010, 10:46 PM
Kevin Doe's Avatar
Where did you find the correct pinout?
Old 05-06-2010, 05:49 AM
BLK02WS6's Avatar
You can't blame a middleman vendor for the quality of a product like that! You should have gone back to the original manufacturer for that kind of problem... and even then, it could have just been a one time mistake. In this "plug and play" day and age, there still is the occasional problem that requires some diagnostics...
