Done deal first nitrous kit on the way!!!!
I just ordered the Nitro Daves 92mm plate kit with all saftey features and gagits, was not cheap but for the horse power not bad. My question is should I spray 100 or 150 shot when I get my tune from LMR?
this new setup only has about 500 miles on it and i havnt went through a bottle yet but im pacing myself so i can add a second stage
but i sprayed a 100 shot on my old head and cam setup for about a year and half
just make sure your fuel system is up to par
This will be my first kit, still a new-be and the fuel is the stock 98ss set up
get the pump for sure, a stock ls1 will handle a 150 shot,you start pushing it when you are pretty modded out on the stock motor and fuel system
get the pump and get it tuned and you should be fine for a long time,just went back and double checked your mods i would get a boost a pump also,it is cheap insurance
but as stated above it is worse than crack so just be smart and make sure to keep it tuned for the shot,dont go trying to just get a little more
it will cost you alot more in the end if you arent careful
