If your running a wet shot your injectors have nothing to do with it and you probably don't need a new chip with a 100 shot. If you are worried about timing and want to pull some you could use a resistor with the Iat and the pcm will pull some timing.
What about the fuel pump? Should i opt for an aftermarket one or stock will be fine? Ill have a pressure gauge and all that to monitor the motor and FPSS maybe a window switch.
