What cleaner should I use to clean fittings in my nitrous system?
I want to clean out a fitting that will be part of my nitrous system. What kind of cleaner should I use? Brake Cleaner? Carb Cleaner? something else?
Thanks!
Thanks!
I had to tap the fitting and I was using some wd-40 while tapping. I just wanna clean out any junk/wd-40 or micro-size shavings that could be in there.
