Bad seal on Bottle
Old Apr 9, 2009 | 02:04 PM
landonew's Avatar
Default Bad seal on Bottle
I have a 15lb nitrous bottle with a bad seal. Who sells replacement seals and does anyone sell a superior seal that is less likely to fail. Is frusterating to get to the track only to find out you can't spray your car.
Old Apr 9, 2009 | 04:11 PM
jdiddyws6's Avatar
Which seal are you talking about?
Old Apr 9, 2009 | 06:00 PM
TARZAN's Avatar
Is it leaking through the valve when you have it closed, or is it leaking where the valve meets the bottle?
-Will
Old Apr 9, 2009 | 06:15 PM
landonew's Avatar
Sorry to be so vague.
It is leaking where the valve meets the bottle. The valve itself is fine... its the circular seal where the valve connects to the bottle.
tightening the valve did NOT do the trick, so it needs a new seal.
Old Apr 10, 2009 | 09:57 AM
TARZAN's Avatar
Just remove it, be liberal with some teflon paste, and call it a day.
-Will
Old Apr 10, 2009 | 10:09 AM
Chris@NitroDaves
Guest
Posts: n/a
Give us a call we do offer them..
-Chris
