mcleod RST twin
You need .500" of stroke from the physical bearing. You need .25" of gap between each disc at time of release. The RST you don't really need to worry about shimming like you do with the Original Twin, because the spacing is machined into the adapter ring. Just bolt it up and go.
http://www.mcleodind.com/downloads/i...etTwin_WEB.pdf
now i just need to get a shim
