mcleod RST twin
Old 04-10-2009, 08:40 AM
boostinsidewayz's Avatar
Default mcleod twin questions
does anyone know the clearances you need to have for setting this clutch up?
Old 04-10-2009, 09:39 AM
Billy M's Avatar
You need .500" of stroke from the physical bearing. You need .25" of gap between each disc at time of release. The RST you don't really need to worry about shimming like you do with the Original Twin, because the spacing is machined into the adapter ring. Just bolt it up and go.
Old 04-11-2009, 06:32 PM
i think i was wrong about it being an RST. i looked over the install directions on your site and it seems to be this one
http://www.mcleodind.com/downloads/i...etTwin_WEB.pdf
now i just need to get a shim
