Installing Nitrous from Nitro Daves have two questions
Do I need a fuse installed for the power wire, similer to car stereo? Also I have the dule (ND) window switch I was told that I do not need the micro switch just tap into the RPM blue wire and bottom throttle body green wire sounds to easy?
Thanks Matt,
The wires I tie into on left side of motor RPM censor wire is blue, and bottom TB censor wire is blue correct? The wires your talking about are attached to the window switch.
Any size stereo fuse type will do?
The RPM wire will tap into the coil pack harness on the passenger side. It is usually a pale green and the second wire from the right.
Yes, the dark blue wire on the TPS sensor is the one you need to tap.
