98+ 4th gen ing 2 fuse
Old 04-11-2009, 03:58 PM
sman's Avatar
Default 98+ 4th gen ing 2 fuse
Put a v8 in a v6 car, the engine is only running on the drivers side 4 cylnders not the passenger 4. The ing2 fuse feeds the coils and injectors on the passenger side. Where does the wire coming from ing2 fuse go? Im really SOL at the moment.
Old 04-11-2009, 08:46 PM
the_merv's Avatar
There are 3 different Circuits that control what you are talking about here with the LS1..
Injectors (Bank 1)- driver's side Injectors.
Injectors (Bank 2)- passenger's side Injectors.
Ignition- controls all 8 Coils.
If I'm not mistaken on some of the V-6 Cars the Injectors were controlled by one Fuse not two seperate ones. If so, you will have to put power to the driver's side Injector Bank in the LS1 Harness.
Old 04-12-2009, 08:45 PM
sman's Avatar
You are perfectly correct, once I applied power 12+ volts to pin b on the c101 connector all issue were resolved.
Old 04-13-2009, 12:45 AM
the_merv's Avatar
No prob, glad you got it worked out.
