which rocker arms?
which rocker arms?
going in 2002 LS1, afr 205's/650 springs, comp cams lifters, cam??...224 or 228 6XX/6XX
so many to pick from, adjustable/ non adjustable, 1.7 or 1.8?
Which ones do you guys use and why.
thanks
thanks
I went with the YT 1.7's on my AFR's. Note that I had to shim quite a bit to get an acceptable wipe. Not sure if you will need to do the same, but make sure you check it. Set up wipe first, then measure for pushrods. The YT's have much heavier shaft between the rockers and larger bearings. They are also lighter over the nose.
