Clutch pedal return spring
I'm not even sure what exactly it's called. The little U shaped spring assembly that helps to return the clutch pedal to it's resting position. Well, I've replaced mine twice after they both failed. I know some guys say "F it" and run it with no spring but I don't like the play that the pedal has at the top with no spring. Has anyone made a custom spring setup or anything like that?
